Brand new, still in box, no lifters, springs, etc. Just the cam itself.
Specs are:
Part number #11-231-3
Grind number #X4 254H
Uses hydraulic lifters
Good low end and mid-range torque and power with good idle.
Its from the Xtreme 4x4 hydraulic flat tappet camshaft family.
RPM range: 1000-5000
Duration: int. 254 ext. 262
Duration @ .050": int. 210 ext. 218
Valve lift: int. 0.505 ext. 0.505
Lobe lift: int. 0.297 ext. 0.297
$90 for the shaft plus shipping.
Specs are:
