SkysTheLimit
Where do big blocks like to be as far as timing goes? Right now it's locked out at 34 degrees but I want to go to mechanical advance. I've got the MSD Pro Billet dizzy and a 6AL. I'm looking at their chart about which color springs and bushings to use and trying to figure out which curve would be the best.
Honestly, it will be mostly street driven and redline on the motor is about 6800 although the rev limiter will be set at 6000. the final setup for my truck will put it cruising at about 2800-3000 rpm. It's a heavily modded performance motor if it makes a difference.
http://www.msdignition.com/dist_mechadv.htm
thx
thx
