Speaking of a world of numbers, I guess the dyno curves do not tell the "whole" story. LS3 is about 200 lbs lighter, and I have read in one my engine books that 500 lbs equates to about 45 hp and 0.5 secs in the quarter in a 3,500 lb chevelle that ran 12-13's.
So the LS3 has lower TQ down low (approximately 460 @ 3,000 rpm, we will give it 480 bc of its weight advantage), approximately 70 ft-lbs lower than the RJ or ATK with equivalent HP. @ 4,000 RPM it then takes off and has equivalent (more or less) tq as the two BBC's. @ 4,000 RPM it has about 50 less hp than the BBC's, but ends up with about 30-50 more by 5,000 RPM where the BBC's drop off, and it continues to make an extra 60 hp until its peak around 6,400 (peak HP around 640, remember I am giving it +20 bc of the weight factor, vs the ATK's 560ish at 5,100 & the RJ's 502 from 4800-5500).
So the LS3 is approximately 10% the under-dog at 3,000 RPM's, evens up in the 4's, & takes the lead in the 5,000s. I gotta think the engine will wind up quicker, bc of its higher peak RPM, will these two setups come out in a wash in the quarter with the BBC winning the 1/8th and the LS3 taking the 1/4 mile? Or is that too much of an assumption to make based upon curves alone? I mean we are running similar drivetrains, I got dana 60's with 5.38's, 38's or 38.5's, 700R4 (which will probably **** the bed once one of these guys gets dropped in).
I guess I could try to tabulate the #'s & drop them into the engine dyno and see what times it spits out for the quarters. I know that is not what our trucks are for, but that is really the only metric I can think of to evaluate the two engines.
Any ideas how to compare the in car performance with the information I have now?
