Not sure what it weighs, I never weighed it.
Lot of story about that truck. It rides level with stock springs. However, the stock springs were ordered with the snowplow option. I custom ordered it brand new from Ford with the super cooling package, towing package and snowplow option. Not sure what they thought of a snowplow option truck going to Florida, but there it was.
It came into the Ford dealer on a truck, and I never saw it. It was sent to a truck body company across town who were waiting for it. It was a 3/4 ton long wheelbase, and they took the back body off, cut the frame to short wheelbase specs and put on a practically brand new short base body from a salvage yard.
Then it went back to the Ford dealer who painted the body to match the truck.
Then I went to work on it.
The bumper is 8 inch wide channel iron, about 1/4 to 3/8 inch thick. I keep saying I'm going to measure it one of these days, but I never do. So far, it has taken out many trees that got in my way, went head to head with a logging skidder blade, and pushed lots of disabled cars and truck around.
No dents yet, although as you can see, it has lost some paint.
The winch is a 12,000lb hydraulic drive Braden, which is rated to 24,000lb, running off a PTO drive pump coming off a NP205 transfer case. I have the bypass on the control valve set so that it will not quite break the 3/8 steel core cable with a full spool.
It will break it after the outside wrap is off.
In the 30 years I've owned it, it has had some changes and rebuilds, but its still mostly stock.........Well original build, at least.
Typing this, started me thinking. The truck rode so well, and I almost never bottomed out the front springs, so I never really considered what all that iron actually weighed despite having been asked many times.
It was standard channel iron, and there are specs for that stuff.
I looked it up, and here is what is listed.
There are three levels of 8 inch iron.
C8 x 18.75........0.487
C8 x 13.75........0.303
C8 x 11.5..........0.220
The second number in each is the weight in lbs per foot. And the number after the dots is the thickness in inches of the flat front part.
If I had to guess, my bumper is the middle one, judging by the way it behaves when I hit something with it. I think the bottom thickness would have dented by now given its thinner than 1/4 inch.
However, the middle one is thinner than 3/8, and it feels thicker. So it might be the top one. Which would make it 18.75 lbs per foot. Its raining today and tomorrow, but I may get out and mike the thickness soon and measure the length while I'm at it.
Meanwhile, it and I are headed to the swamp tomorrow. My hunting camp is still open, and the river is only about 2 feet over the road right now. My 12.50/33s will get me in just fine.
