Clod_King
I am trying to get the size of the bolts/screws used to bolt the tire bead to a wheel...
I am talking about the kind of bead lock when you drill holes though the lip, and literally bolt the bead to the wheel.
I know it's been discussed, but I never found out what size screw or bolt to use. Or to use a bolt or a screw, or a self tapping bolt.
I figured the bolts threads would be too tight to hold the bead to the wheel securely enough.
And I figured tightening a screw down throught the bead of a tire would be a huge pain in the arse . And I also figured you'd ruin the head of the screw before you could tighten the fastener all the way down anyways.
Now the self tapping screw would be the easiest, and would also have a decent thread spacing to securely grip the bead.... But I thought you'd most likely end up going straight through the bead, and get an air leak...
And if you went to a smaller fastener (the self tapper's) there would be less threads engaging the bead, so it would be worthless....
You guys see what I am getting at?? Or am I just talking out of my poop hole??
