Beag's 67 Chevelle. Supercharged Summer
I thought it had a 496 for some reason..... Or maybe that's was the plan for it :thinking:
If you had a fat block it'd have enough power to spin both even with an open diff :D
I just realized the error of this statement..:doah:
You can't put a fat block in this car.
Cause then you'd HAVE to scrap the 10bolt anyway:D
Don't you have a few laying around?
Bring one down.
I only have 1 laying around. Other 2 are being used.
And the one that's laying around is slated to be built for the dually. Then the one from the dually will get sold or :dunno:... No idea yet.
Lots of times, it's a huge headache. Iron workers have their tricks. Sometimes a big vise grip works, or they weld a tang on to the head of bolt to hold it with a vise grips or pliers. or take the nut from another bolt welded onto the head so they can actually put a wrench on the bolt head to hold it.
the bolts are junk at that point in time so it doesn't really matter if you weld to them or do anything else.
We use those tricks around here, but we keep pretending that more professional organizations have more professional ways of fixing things. Maybe not? Perhaps I overestimate the gap between millwright tricks and professional fabrication work. :dunno:
When I was a millwright we did that with all stainless bolts. Once it came out it was pitched. Didn't matter if we stuck em in last week.
Case in point, we routinely reuse stainless bolts. If the bolt hasn't stretched, why would we toss it out? We have lower standards than bridge builders. Perhaps it's good that we're not building bridges?
But it sounds like iron workers know how to do hack work, too. :dunno:
What are you going to do to build it? Stroker crank? Different heads?
We just spent too many hrs fighting galled bolts. Boss made the decision to just get knew every time. 90% of our stuff was 1/2" or bigger and installed with impacts in a hurry. So 1 time you'd get away with it, but maybe not so much the 2nd or 3rd
Them heads I picked up, 063's I think, and a basic rebuild with flat top pistons and cam for towing. Not a hotrod, but a good steady tow machine. Trying to shoot for 9-9.5:1 compression, a step over an RV cam, and a tall dual plane intake.
I'm thinking that should be good for better low end torque, but ready to do a few more RPM than stock for long hills.
Once I pair that with an nv4500 I should be able to trailer shorty anywhere I want to play.
If ironworkers or fab shops were perfect, I wouldn't have a job.
It's not that people purposely do bad work. 99.9% of the time they don't know.
So it's not on the workers that perform the work. They want to do the right thing.
It's 100% on the companies management.
Shops have alot better way to fix things. But your really limited by tools in the field. You really only have a welder, torch, and some hand tools...
In a TC it's not possible to go through several cycles.
You see the splined end.View attachment 341900
The splined end breaks off once the bolt is tensioned correctly .
Hence the name tension control. It allows any monkey to get the correct tension on a bolt.
It's a life saver for me..as I can trust the bolt. And not the person installing bolts.
Unfortunately these days I build more bridges then buildings. (Hey I didn't realize that myself until this moment)
And those aren't allowed in bridges yet.
Anyway, they are a single use bolt.
Once you break of the splined end.... And if you have to remove it for a reason..... It's a new bolt going back in the hole.
Yeah we use a lot of these at my jobs on water pipes, it's a similar concept to torque to yield but it's more idiot proof, just keep going till it breaks off.
Your talking about the tee bolts for the ductile iron bell collars? That snap off the hex nut once tight?
Yeah I put in water main and sewage/storm water pipe.
And I work with high pressure/ High temp pipe, but thats a different animal.
Yep
Since we talked about these the other day lol.
Current shop art... And planned location.
Not sure it this is worth updating or not but it's the only thing I actually finished. Worked a bunch on other things. But didn't finish much.
The old torker manifold only had one place I could put the coolant sensor. And when I did that it made it so I could use my old water neck. So I snatched one from weiand and bolted it down with a 195 thermostat.
Somebody said @6872xtc liked little holes?
View attachment 342043 View attachment 342044
That should help things out!
:waytogo:
Now what's the secret that showed up from Summit?
No chevelle work today. Gassed up the STS-V and headed out of town with the family. 76 degrees out, open sunroof, 200+ miles, a state park and a taco truck.
Life doesn't get much better then that.
I was 100% with you until you mentioned the taco truck. @ktmoutfront may have cured me from wanting those anymore. :rolleyes:
The rest of it sounds like an excellent reason to have no Chevelle update.
