how often should the front and rear bearings be repacked?
how long should the wheel bearings last? how about the axel bearings?
Front bearings that are kept properly greased will usually last a lifetime BUT the one thing that will kill any wheel bearing is running a wheel with a lot of back spacing.
Rear axle bearings will usually last a lifetime as well if the diff oil is kept full. Once again running a wheel with a lot of back spacing will prematurely kill the bearings as well.
Why does tha backspacing affect the bearings? .
Why does tha backspacing affect the bearings? i always assumed bigger tires would chew the bearing prematurely... also where do get the timken's ive search a couple of places and havent found them, and Napa has china and spain stuff.. wich both suck by the way i preffer mexican if i had to choose from thoose 3.
Personally i check my bearings before and after i go out to the trails if i hear something around the i will check them to.
