BloodMoon
Registered Member
My truck, like most has some rust, but I have a major concern with one location, the passenger quarter panel, right where the fiberglass shell attaches, its a pretty long hole and the rust has gone all the way through to the point that I can push on the outside skin and flex the panel inwards. The inside skin appears to be ok.
I can get a new quarter panel assembly locally for about $300, and a repair shop wants $500 to graft the new outer skin and replace the rusted one.
I don't really have a location that I can cut and weld myself, nore do I have a welder.
My questions is, if you were me would you:
1. Do it right the first time and replace it for $800
or
2. Sand down the rust and remove big/loose flakes, coat in rust bullet, apply fiberglass cloth while wet and finish off with a second coat of RB? $50 for a quart of RB + $20 for fiberglass cloth.
I like number 2 myself for a temporarily permanent fix...
What do you think?
or
What do you think?
); I will just have to buck up and save up to do it properly- buy once and cry once right!
). If you're getting the whole quarter panel outer skin like the one that LMC carries you could use 3M's panel adhesive to attach it. This is assuming that you remove the entire existing quarter but leave the bedrail that the top rests upon. The quarter panel has a lip that wraps around the B-pilar at the door where you'd glue it. For the top of the bedside, cut the innermost lip off the new panel so it sits flat on your existing bedrail and glue those two together. For the rear where it attaches to the tailgate post I'm pretty sure there's a lip there too that you can glue. The body lines would be slightly higher but you could probably make adjustments in the door and tailgate to compensate for it. Hopefully ryoken will say why this is or isn't a good idea.
