vortec
after trips that stress the brake system (hill descents, etc.) i've found that a small amount of brake fluid has been forced past or through the gasket between the master cylinder and brake booster. it's fine, otherwise. when i install my 4" lift, i plan to use extended stainless brake lines, and replace that gasket, too (bleeding once is better than twice) but with the higher pressure, i'm concerned that i'll blow out the new gasket, too. i haven't come across a super-strong one or anything.
i've heard that gm 3/4 ton rotors will fit with my half-ton calipers, but maybe not with my 15" wheels.
