handloader90
Building!
I want to run 35's or 37's on:
10 Bolt/10 Bolt or 10 Bolt/12 Bolt or D44/12 Bolt.
I currently have a D44/12 Bolt, but I want to pick up a spare set of axles to work on.
I know a D60/14BFF setup is the way to go, but I've looked high and low and haven't ran into exactly what I want. I can find the setups mentioned above a dime a dozen and for next to nothing
My trucks a daily driver and it won't be seeing rocks where I am, light bogging is the only thing I will do other than driving to and from work. I'm not very heavy on the throttle unless I'm passing someone.
What can I do to run one of those setups safely and not have to worry about breaking something every time I pull out of the driveway? I've read some threads on here about guys running 37's on 10 Bolts with success.
What gear ratio is going to be best for 35's
What gear ratio is going to be best for 37's
Run open, lockers in both, LSD in the rear???
