carpeonnel
Haven't been on here in quite a while as I've gotten heavy into mudding ATVs (that and it's cheaper than breaking parts on my K5
). I toyed with the notion of selling my K5 for a while and I've decided that I've done too much to my K5 to sell it after 10yrs of ownership, so now I'm gonna change a few things to make it tow better and wanted y'alls opinion. Plan is to fix the A/C, go thru all the window motors, redo seats, new dash, new carpet, andmake it comfortably tow up to 5K lbs without much issue
My stock TBI350 is getting tired and I've thought about buying like a long block 383 in the neighborhood of 300hp/400torque. I've also priced out some nice long block 350s with 300hp/340torque for about $500-600 less than that stroker. In y'alls opinion do you think the 350 would do the job equally as well for the less cash?
Second question: I will be getting rid of my 38s and dropping about 2-3 of lift and going to some 35-37in range tires to reduce some rotating mass, but who makes a solid 35-37in in all-terrainish type tire these days for a decent price?
Can't really change gear ratios as these 4.10s will have the motor wound up at 65mph since it has no overdrive and don't wanna go back to a 700r4 for towing
My K5 is still setup with 350TBI/SM465/205TS/HAD 1350 shafts/14b detroit and disc'd/d44/crossover steering/YJ shaft/etc...
If y'all have any more input or insight on some things to do to make it a reliable tow rig I would appreciate. CK5... best site on the net
). I toyed with the notion of selling my K5 for a while and I've decided that I've done too much to my K5 to sell it after 10yrs of ownership, so now I'm gonna change a few things to make it tow better and wanted y'alls opinion. Plan is to fix the A/C, go thru all the window motors, redo seats, new dash, new carpet, andmake it comfortably tow up to 5K lbs without much issueMy stock TBI350 is getting tired and I've thought about buying like a long block 383 in the neighborhood of 300hp/400torque. I've also priced out some nice long block 350s with 300hp/340torque for about $500-600 less than that stroker. In y'alls opinion do you think the 350 would do the job equally as well for the less cash?
