bot0611
Ok so i took the damn T-case lowering kit off, my tail shaft sits @ -10* Y and my pinion angle sits @ +16* Y so the the choices ive seen here are torch and re weld perches or shims.
Ok i think i got it right now, both tailshaft and pinion have to point and the same angle one up and one down, am i good here??
so should i just get 6* shims on back, or rotate 6 * the axle and re weld.
Did i get it ok.
Thanks in advance guys.
Did i get it ok.
