Before and after
You took the top off and painted your rims black? :D
J/K How about some specs so we know the amount of work you put into it.
-Avery
-Avery
Ok well the first thing I did was a 4inch skyjacker spring lift, then I decided to do a 3/4 ton swapp and that was kool for a while and then CK5 took over!!:D Did a SYE on the 241 and clocked the thing flat,Ord disc brake swapp on the 14ff which made a big diff (no pun intended haha) put a 60 up front with Detroits front and rear, Ord crossover,Ord steering Braces, custom 3inch exaust, shaved the axles for a little more clearance, 2 piece front DL with 1410 joints for pinion angle, and some bashing on the rocks:D
