Before I place pistol next to my head...
caleb22
South Carolina
Please give me some good news.
Besides the heck of a time and 5 hour search I had finding someone to mount my US Wheel chrome rims to my new Goodyear 33x12.50x15 MTR's, I now have the problem of mounting them on my 89 Blazer. When I placed the tire/rim on the Blazer it touches the brake caliber, thus not allowing the wheel to go all the way on. When I ordered the rims I made sure and checked the backspacing I needed before I placed the order.
What in the world can I do to fix this dilemma? Let me know what info you may need to help me...guns loaded, just sitting here with it cocked.
I started the grind process on the driver side wheel caliper. I spun the wheel a few times and found the high spots. However, after a small amount of grinding I have realized that a large amount will need to be done to the caliper on the side.
Would it be against any safety rules for me to use a 1" spacer in the front to get the clearance I need? I just ordered a 2" spacer for the rear from Harold's.
Keep grinding, there is a lot of meat on the caliper...
rene
The problem I see is that there are two bolts that hold the caliper on (I'm not a brake guy so forgive me). I'll have to grind them too.
89GMCSuburban said:
What's the backspacing on the wheels and what axles do you have?
might have been good for someone to ask that kind of question before giving advice. :rolleyes:
are the wheels 8" or 10" wide. For 8", i believe you need 3 5/8" backspacing. i don't know about 10"s.
I do not know about 4 3/4 backspacing but I do know that a 15X8 with 4 1/4" backspacing will fit with no problem on your setup. I have to grind the **** out of my front 60 to get the same combo to fit.
Ira
These are the specs of what I bought:
Brand:U.S. WheelProduct Line:U.S. Wheel 97 Series Chrome Modular WheelsRim Diameter (in):15Rim Width (in):8.00Backspacing (in):4.75Beadlock Functional:NoBeadlock Included:NoRim Material:SteelCenter Material:SteelWheel Finish:ChromeLug Nut Seat Style:Conical seatWheel Construction:2-pieceConical Seat Taper:60 degreeHub Centric:NoCenter Bore Diameter (in):4.28Center Cap Included:NoOffset (mm):+6Valve Stems Included:NoQuantity:Sold individually.
Wheel, Chrome Modular, 15 in. x 8 in., 6 x 5.5 in. Bolt Circle, 4 3/4 in. Backspace
Do I need to return these and get ones with 4 1/4 or 3 5/8 backspace?
Did you say 6 lug, as in 1/2 ton? Should be no grinding required. But, 4.75" back spacing is a bit much...
Will these work? I'll just sell the other ones...
Rim Width (in):8.00
Backspacing (in):3.75
Material:SteelWheel
Wheel, Chrome Modular, 15 in. x 8 in., 6 x 5.5 in. Bolt Circle, 3 3/4 in. Backspace
Ya they sure will. The only problem with your other wheels is you are hitting the dropwell of the rim with the caliper due to the large backspacing. 3 3/4" backspacing will keep your scrub radius near what it is with stock wheels.
Ira
