A couple of weeks ago my 16yo daughter bought a 2001 Lexus ES300 as her first car. Like all older cars, it had a problem pretty much immediately, the alternator was bad.
I decided it was a good time to get her more familiar with her vehicle, so I had her change the alternator with my help. Alternators are super easy, so why not? She is a good listener, so is doing exactly what I tell her so this should be no problem.
Fast forward to hooking the wires back up to the new alternator and I casually mention "BTW, usually you are supposed to disconnect the battery before doing this. I forgot, but we'll be fine."
Get everything hooked up, have her go start the car and it starts right up!
"Um, dad, none of my gauges are working and it won't shift."
No power getting to anything other than the engine, and every time we start the car it gets harder, so obviously the battery isn't charging.
I spent the next hour checking fuses, pulling the alternator back out, and going to have it tested (it was fine), and generally trying to troubleshoot before it finally hits me that there must be an alternator fuse or fusible link somewhere that got blown. Yup, 100amp fuse marked "ALT" that I overlooked. Looking back, I can remember a small spark when we disconnected the positive lead from the alternator.
And that is how taking a shortcut (not disconnecting the battery) can turn a 20 minute job into a 2 hour job.
At least my daughter got 2 lessons out of it.
