For some time I've needed a good belly pan on the bottom of my truggy, but I struggled coming up with idea's. I didn't like the idea of having a crossmember/bellypan combo..I wanted a pan that was lightweight but strong.
I settled with a stock crossmember with 1/4" steel plate added. I made the bellypan from 1/4", then welded angle to grab the edge of the stock crossmember. I added 1 3/4" Dom tubing to create a skeleton for strength.
I cut .188 rectangle, used that for brackets...5/8 bolts.
I thought I'd test it before adding more backets and add some steel to the front to smooth the belly..I'm very happy so far..
Have anything to add? I'm always looking for idea's...
