What is the point of bench bleeding a brake master cylinder? Is there an air pocket in the MC that cannot be reached with regular two-person pump bleeding at the four corners plus prop valve?
Also, if bench bled, how is this done without getting brake fluid everywhere? How do you get the plastic bleeder stuff out and thread the metal brake lines back in without making a mess?
