Bendpak
i have used a lot of brands in my time frame . bend pack is more china these days and it shows it . also there LOAD going up and it bothers my ears . . to many years un protected in the loud shops .
my friend just got 2 new rotory lifts 10k spec in his brand new shop and he spent about that price and the quality level is a LOT more over the 3 year bendpack he has also .
the rotory pair was installed for the price your link shows per lift . he even got it with the newer 3 stage arms and screw adjuster feet and spacer tubes .
forward lift is rotorys off brand with less fancy stuff . good lifts i know a few shops local running them for years no problems .
my buddy was ready to order 2 10k bend packs but they were 3+ months out 1 month ago and still could not 100% say when they would come in . so do some more home work and see who has them IN STOCK and has good service for install and after the sale .
anymore questions just ask . :waytogo:
I have that same one. Prices have gone up over the last 1.5 years. Wow. No issues. Went up easy by myself. But I have done a few before.
I have used both rotary and bendpak
A few Mohawks.
All the lifts were at least 15 years old, some more than 30. So knowing the current quality is what I'm after esp with current prices. I think they have gone up since September.
My Dad has the Bendpak 10K in his home shop for 5 years now. Its nice. I have used it for a couple lift kits and some random maintenance, no complaints. Dad was looking at the next model smaller and the rep said that the price difference was almost nothing, get the 10K. He was totally right and now there is a Dodge dually in the mix and no worries about putting that heavy thing up in the air when needed. I haven't personally seen the dually up in the air yet but it shouldn't be an issue.
My Bendpak is the same as linked. 5 yrs old and although not a lot of action on it, it does usually have something ”up” on it. Had to make one cable adjustment to it to even out the arms coming down, but otherwise it lifts my 2500HD Duramax no problem. I would buy it again. I think mine was around $2800 shipped 5 yrs ago. At that time the USA made one was about the price of the one you listed now.
I have two I put in my shoo 20 years ago. If I was to do it again, I'd bite the bullet and go Mohawk.
The Bend-pak is decent, but it is mid level for sure. Lots of cut corners in manufacture.Repair parts are overpriced. For home use, it would be plenty
I forgot my buddy with the bendpac less then 3 yearz old now has it in his new shop with taller ceiling and wants the 2ft height adapter kit for more room with the box trucks . They will NOT sell you a kit unless purchased with new lift only . He is not happy with then on this .
1st customer, my brother's hooptie, needs brakes. Pads have decent linings but rotors are warped.
Floors not level had to chock car to keep it from rolling, while I set the arms.
easy fix . . cut off 3" or so chunk of angle iron and bright spray paint color it . nice wheel chock . i have reg ones but this is my every day go to cause i made it .
and that choice of first life dont count :doah:
