Mav2u
Okay, finally got the truck away from the stupid Autobody shop and back home in the drive way.
I had my previous post about how the truck had an accident on the passenger front fender and tire. The front right tire ( passenger side ) is still pushed back what looks like an inch or two. I looked at the spring pack and it doesn't look like it slid from sheering the center pin on the spring pack at all. Looks like it is still in the same place. The front sway bar connections look about the same so the axle doesn't seem like it would be able to move backwards on one side without tweaking on the sway bar.
Could the axle tube be bent? It looks straight as an arrow with no visible stress or crack marks of any kind.
I know that the steering knuckle steering bump stop bolt was completely mashed flat half way down the bolt from the force of the impact ripping the steering wheel full crank to the right when the tire caught on the front end of the other car.
What else could cause the wheel on that side to be back farther on just the one side of the vehicle?
Here is the .pdf of the alignment after the accident.
Alignment PDF after accident
Here is a photo of the passenger side after accident.
Right side after accident
I will have to get a photo comparing the two sides to show how the difference is on the right side with the gap at the back fender a full 1 inch shorter or so.
why thanks for swelling my brain more.
