Bent axle?
RENO88
San Diego
So I'm having vibrations at various speeds. I rebalanced my tires (33" BFG's) And I have no lift, so its not pinion angle.
When it does vibrate, I can either let off throttle, or quickley accelerate and it'll go away. My other thought would be a bent rim, but it does'nt vibrate at a certain speed. What are your thoughts? Yes I did a search BTW.
Also, I did replace the U-joints all around. Drive shaft balance weights are still there.
Your axle would be in pieces already.
Seriously, that's about the last thing I'd consider. Can't be much help beyond that, I know there is a section in the service manual (at home) that lists common vibration sources. I can get to it when I get home. I thought a few more would post stuff up though.
Is this a slip yoke driveshaft? If two piece, are the yokes in phase?
Your shaft could easily be out of balance. I'd go get it balanced, or see if an driveline shop can help you out.
I vote driveline issue... Even if your u-joints are new, you still need to check for excessive play in any of the yokes. Also a loose pinion will do what you say. Typically, something that is bent or out of balance will vibrate all the time and not just from load to coast.
Bingo. I balance tires all day long, and bent object (wheel etc.) will tend to get worse with speed.
Check you slip yoke in the case, see if there is any play.
I'll have to check my yoke later. That sounds like a pricey fix. Yes? Also, would the balancer detect a bent rim?
i vote driveshaft
i've had some weird,odd vibrations on various vehicles and the driveshaft is where i'd look, other places are(and i doubt it) the crossmember and the trans mount=check those for side to side mis-aligment/looseness,get a floor jack and a buddy and jack the ass up and have yer buddy get in/put it in gear=you'll see a bent drivshaft or wadded u-joint bearing
check your motor mounts, they can slightly adjust joint angles. also cheap parts store joints arent as good as say spicer.
