79bonanza
Okay say you had a bent spindle and you had a lot of positive camber, in a pinch couldn't you just pull the spindle and rotate it 90 degrees turning the camber into toe, then just adjust the tierod.
I know it would affect your steering geometry but would it work.
I'm not trying this I'm just wondering
Just seems like you are thinking way too much about a part that should be cheap and easy to just replace.
