Fred_M1010
Have any of you managed to bend a stock dana 60 spring plate?
The front u-bolt eye on the passenger side got bent down a bit when I torqued down the u-bolts.
I torqued it to 150ftlbs, is that too much?
The upper axle shim doesn't cover the whole length of the spring plate.
Could that be the cause of the problem, or is it common that these plates fail?
. If you look at the driverside, both ubolts are going towards the back and the passenger side kinda going straight up and down. I still think its a fatigued plate, get a new one.
