Interesting, I never knew there was a mechanical IP 6.5TD out there. Not to hijack, but perhaps expand from the OP question. what about hybrid engines? or... for less cringe factor, frankenstein engines.
For instance, im planning on basically replacing the entire drivetrain in my M1009. Obviously the axles, but also a NV4500/Lo-Max NP205 (probably over the next 10 years or so
)and driveshafts. Might as well build a 6.5TD and swap it all at the same time to minimize downtime of the truck... and then put the 6.2 in something like an impala
ANYWAY.. If I were to grab one of these 599 6.5TD's, id want to swap over my military spec IP due to its hardened internals and ability to swallow kerosene, diesel, and biodiesel with aplomb. But how bout the heads? the 6.2 has larger valves and ports correct? And the J code intake with no EGR port. Effectively a 599 with military heads, intake, and IP. Any drawbacks to that setup?
or with using the 6.5 heads/intake/IP on the 6.2? IIRC they are completely interchangeable.
