Best cheap option to fix this rust and paint?
RockBottomRacing
Simi Valley, CA
1991 Suburban, she’s going to have cut fenders and wheel wells and be up on 37’s. She’s going to be abused, I just want to put a new shine on her. Paint peels more and more every time I wash. The trim glue is rock hard and doesn’t want to come off, about to start tapping a plastic wedge against it. Eraser wheel didn’t work for nothing. Just wanna get her presentable. I’m going to be painting with a foam roller, color sanding on between coats but wanted to see what options I have as far as stopping the paint peel underneath and fixing this rust. I’m all ears!
Only one of your pictures work.:dunno:
Sand the rust with some 80-150 grit sandpaper on a DA or whatever powered sander you have then roll on some epoxy primer. https://www.paintforcars.com/produc...6O1jfCChUxO4L4Ix9wP3VeXcUTz7omsRoCGtwQAvD_BwE
After the epoxy dries for a couple of days you can sand it, then you're ready to paint.
Should sand the whole thing, not just the surface rust. The clear will continue to fall off, which makes it a poor surface to paint over.
I'm sure our resident body and paint guru @ryoken will expound on having a good surface to paint on...
I agree, you will want to get all of the loose paint off by pressure washing and sanding.
I sent the wrong link for the epoxy primer. The above link is for direct to metal primer which is ok but I would prefer epoxy in your application.
https://www.eastwood.com/eastwood-black-epoxy-primers.html
ok, here we go... on the cheap...
your biggest issue is the stopping the rust... we'll start there.... i would mechanically remove as much as possible, DA with 50, 60 grit.. grinder, flap wheels, wire wheels, etc.... if any is left, I'd probably throw some converter on it before a primer... a qrt of ospho would do the roof easily ... re-DA with some 150 to 180 to put an etch to the treated areas..... prime.. epoxy is a good choice for raw steel..
just keep in mind the old adage, "your paint job is only as good as the substrate"... so a perfectly sanded smooth primer will yield the best paint work... just make sure everything is at least scuffed, no shine...
as for the rest... yeah, powerwash it and blow off as much as possible.. than take a DA to it.. something around 180 is good.. see how it feathers at the peel areas, it may continue to fall off.. sand till it's adhered and actually feathering.... these feather areas between layers are actually the most important part to get some primer on if you can.... and keep to a minimum... those open edges are what will show thru, or worse, solvent cringe....
prime the rest as you see fit.... DA or wetsand out everything with 320 or 400 for paint... the longer you can wait between sandings/coats in your topcoat, the better... I assume your running some sort of air-dried enamel like a rusto or tractor paint.... stuff takes forever to dry, and doesn't sand particularly well, so patience is important... do not try this with a metallic..
any ??? ya think I can help with, holla...
