Ideally I'd like to remove the hinge pin and leave each hinge half on their respective body part. I'll be installing ORD tube doors which use the body half of the hinges.
I tried using a hammer and punch to drive the pins out but they didn't move. (I didn't get ugly with them, yet)
I thought about cutting the pins but there doesn't appear to be a clear shot.
I know I can unbolt the hinges from the door shells but I'd like to avoid that if possible. It would be nice to be able to just drop pins in if I ever reinstall the doors (no realignment).
What about the wiring harness? It looks like the boot is riveted to the body, do you typically get the doors loose and then drill the rivots? Seems like a pita.
