best fuel pump
NEK5
3/4 ton status
Ipswich MA
Not to edumacated in the operation of carbed rigs, but thats what it`s gonna be when its complete. I think I still have the stocker I pulled off, but in case I don`t, what should I run? I`ll have a return line, as well:wink1:
u need an in-line fuel pump that pumps around 5 psi of fuel pressure...you'll need to use your return line as a vent line for your gas tank...and make sure you have a vented gas cap...
The gas cap is vented, and the sending unit I have is a 4 output, cap vent, vapor, feed, return.
