I'd go (and did) with one of these before that:
https://www.waytekwire.com/item/46346/EATON-s-Bussmann-Series-15303-6-2-4-RTMR-Mini-Fuse/
Still not as versatile as I'd like (being able to gang up a few fuses and/or relays instead of all or none) but the best I've found so far to keep wiring clean. 10 fused circuits isn't that many either, if it was a bit larger it would be useful for a longer period as you add circuits.
I wasn't able to find any for sale, but Delphi also makes or made a modular setup that shouldn't be real expensive, but I like the Bussman one because there are many options on what side is ganged or not, cover, etc.
I'm presently running an 8 gauge wire to my auxiliary panel, but I'm not running the cooling fans off of it, just injection stuff, backup camera/mirror, etc. I will most likely run the high speed heating fan off a relay, and may need to consider increasing the feed wire size.
I didn't post earlier in this thread because of the title...but for the most part I'm done messing around with junkyard parts, at least for electrical like this. I don't have as much time as I used to, wrecking yards are getting harder and harder to deal with, and being able to run new wiring, new connectors, and not have any solders/splices to fail is a huge benefit IMO. I can crimp a ton of those connectors a lot faster than I can solder/shrink tube (or crimp and shrink tube) a bunch of random wires, especially as the wires get larger.
