I'd like to put a lift on my bone stock 78 blazer. I've done research online and searched the forums here and I've decided on a 4" lift to fit 35" tires on 15" wheels. Hopefully I won't need to trim the fenders to avoid rubbing. This truck will be driven on the weekends mostly on paved road. If I do some offroading it will be on the beaches here on Long Island or on backroads in upstate NY and I don't plan to flex the truck to its limits. I just always wanted a lifted truck and a little ground clearence will help when hunting and other light offroading. I will probably not be towing anything either, if yes, it won't be anything large and heavy, maybe a couple ATVs or a snowmobile. I would also like to keep the option of putting on a plow in the future, dunno if that matters when choosing a lift kit.
It seems a lot of people use the Tough Country and Rough Country lift kits. I plan on going with new leaf springs in front and rear since mine are all original and they must be sagging somewhat by now. They don't look it though and the truck only has about 96k miles but I figure they are quite old. Sounds like the Tough Country springs offer better ride quality and the Rough Country are a little on the stiffer side.
1. For those w/ a 4" lift or similar, what brand did you go with and how do you like it?
2. Will I need to trim fenders? It may be worth mentioning that I have factory diamond plate running boards.
3. Other than a lift like this one:
http://www.roughcountry.com/chevy_4wd_77-87_4.html
will I need to purchase anything else such as single or duel steering stabliizers, extended brake lines, transfer case drop kit, frame support, etc?
My only fear is lifting the truck and causing problems in other ares like leaks, excess wear, excessive vibration, etc. Never did this before so just trying to learn. Thanks in advance.
