decided to use a line lock with my brake setup on my dick brake conversion of the 14 bolt
Never needed a brake on mine............
I agree you need to check to see if a line lock will meet the inspection requirements.
If it just has to hold 1500 in drive, find a big rock or wheel chock.
Back when we had inspections here in Fl, I had to pick and choose where I took my old Jeep.
The E-brake was a single shoe drum brake on the rear drive shaft that you engaged by pulling up on a dash mount handle.
Didn't even had the advantage of a lever. The only time I tried to use it to stop, it caused a loud grinding noise and smoke came up through the floorboard as the mud and stuff burned off the shoe.
I think the Jeep got faster.
It might be the same in your case. Ask around and see what shops will take what for the requirements.
If the inspections were actually about safety, then an E-brake should be a separate mechanical backup to the hydraulic.
Preferably at the wheels to enable it to stop the vehicle even if the drive train failed.
But, since most of these systems are all about collecting fees and fines, you may be able to game the system with a line lock.
If you had some way to lock the front drive shaft, you could use your transfer case as the E-brake.
Just shift into 4wd, and its not going anywhere.
