punchinghorse
Uppercutting Equestrian
Believe it or not, my newly purchased '73 K5 still has points. After just having the carb completely rebuilt, it still idles funky and misses out occasionally. The points, condenser, and plug wires look to be about 15-20 years old. I was going to upgrade to HEI anyway so it seems that now is the time. All of my previous older trucks had been upgraded before I bought them so this is my first time. I'm looking at just picking up an HEI dizzy from Jegs for $95. Would this suffice or are some brands better than others?
This is a weekend toy and I don't really care about top of the line, just want something that is high quality and will last. Engine is bone stock and will probably never see above 4k RPM, if that.
Also, is anything else needed for the swap? Jegs mentions needing a new power/tach lead, and obviously new plug wires are in order, but I figured I could just pick up that stuff at a local parts house.
) Use a fairly heavy wire like #10 or #12, and don't mess with the original dizzy hot wire. It goes through a resistor along the way and won't give you full power.
