william_7900
Registered Member
Guys,
I'm putting this thread in the Garage instead of the diesel forum because more people may see it and respond.
I'm looking to upgrade from my 350 to a '93> GM 6.5L Turbo Diesel and have been watching Craig's List but not much luck.
Any thoughts on the best way to locate a good engine?
I'm guessing I may get the typical "why are you doing that?" type questions so I figured I would go ahead and answer. (not trying to start an argument on the merits of a diesel or a gasser, although your thoughts are appreciated)
1. Better gas milage than a gasser
2. More torque at lower RPM'S
3. Can run additional types of fuel
4. Fuel injected
5. Swap sounds like a fun project
6. Depending on what I can find, should be less expensive than building a fuel injected stroked gasser
7. Will bolt right up in my 71' Blazer
8. I like the way a diesel sounds... :-)
I am not good at finding good parts like this and wanted any info on what you all do to find stuff like this.
thanks as always for the help
William
4. Fuel injected
William
