Best place to get 'ignition hot' current from?
TX Mudder
Houston
Best place to get \'ignition hot\' current from?
What is the best place on the fusebox to get ignition hot from? I need to hook up my tach and my elec. choke, where did you guys tap in?
-- Mike
Re: Best place to get \'ignition hot\' current from?
Should be a terminal marked ign. This is only hot when you turn on the key.
If you poke around with the key off and on with a multi meter, there are a few open places in the box that you can plug into.
Mike
See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
Should be able to go to the hot side of the solenoid on your starter for the electric choke. In the fuse box there should be plug ins next to ignition hot items. You can also hook up to accessory items for the tack, try the plug next to the stereo fuse
I thought I was wrong once,
but I was mistaken
