Best prices you've seen in 5200 lb axles
blazinzuk
Buzzbox voodoo
Rexburg Idaho
Or close to them .
I'm guessing that my trailer weighs around 1800.
Horton weighs around 5k ( guess)
Well that puts me at 6800 lbs in a 7k trailer.
I let a guy borrow my trailer he lost a bearing and the spindle is trashed.
It is on my idler axle, only one axle has brakes
I hate putting another 3500 k axle in.
Trying to scheme a way to up grade.
Not to mention my axles are a less common 5x5 bolt pattern.
I thought about trailer house axles but it seems the 14.5 tires have gone drastically downhill.
Still investigating putting normal hubs on the trailer house axles
just buy new of what you want and be done . i would do brakes on both my self .
dexter is a big name in axles . forget the other big name company .
i called dexter for my goosneck project . 2 10k torsion axles with oil bath or grease hubs and brakes on both is around 2500-3k price to my local dock . not bad i think for that big and torsion flex no leafs . better ride .
I don't have a ton of money to do this with.
If I did I would be getting Timbren axleless stuff.
Might just have to run 2 different bolt patterns for a bit
Thanks man. I decided I really couldn't afford bigger axles right now.
But getting the proper axle has been nuts. You'd think when you order a specific axle and they send you the wrong one, the company would make it right. Well Trailer parts unlimited. Said sorry nothing we can do about it. Come to think of it I'm starting another thread
Lots of guys looking for 7k’s for about a grand. Sell your trailer and upgrade. You can get into a pj buggy hauler 10k for 3500 during sales. Then you don’t have to worry about axle troubles anymore. That’s the route I will be going.
I'm a couple years out. But I'm gonna build my trailer this time. Gonna cost about 2500 to build with 7k axles and good trailer tires but could likely get it done for 2k, but I want a lift so my trailer is just gonna have to work for now
Yah I hear yah. I have a lift so....
I know this thread is over a year old, but I thought it was worth sharing some input as I just went through this. I have a 18' flatbed that has dual 3500lb axles with brakes on both axles, nicer tires that I just replaced within the last 1.5 years, but I too wanted to upgrade my axles. I always knew with just my blazer on it was pretty much maxing it out (though I had loaded it way heavier before...not cause I wanted to, cause I had to). It's done the job since I've owned it. Blew a few tires here and there (the ones that blew were older) and I blew 1 bearing last year.
I contemplated just selling the trailer and buying another one that was already 10k rated (as mentioned above), but I have some time and money into this trailer already all within the last 2 years (brand new wood deck I installed, built my own drive over fenders, welded on d-rings, bla bla). So wanted to see how much it would be to just upgrade the axles. I ended up finding these guys:
https://thetrailerpartsoutlet.com/5k-5-2k-dexter-trailer-axle-5000-5200-lb-electric-brake-6-lug/
(you obviously need to pick the correct hub face/frame width axle for your application)
I ended up ordering these exact axles through ebay (still shipped from the same store) cause through ebay it was offering free freight shipping to my house. So after it was all said and done, I got 2 brand new 5200lb axles with brakes on both, with new leaf springs and u-bolts, shipping directly to my house for $950. Obviously I then had to get new rims (current rims are 15x6 with 5x5.5 pattern, and new axles are 6x5.5), but found some new 15x6 trailer rims with 6x5.5 pattern on amazon...got 5 of them for $250 shipped to my house. This will literally be a Saturday afternoon of unbolt current axles/leafs, bolt up new axles/springs, splice couple wires for brakes, have my current tires swapped over to my new rims, and then go. And added to this, my brother offered me $600 for my 3500lb axles with the leaf springs and 5x5.5 rims, cause he wants to build a trailer to haul his Camaro dragster. So for a grand total of $600 out of pocket I will now have a fresh 10k trailer. Sure, I guess I could have sold the trailer, (assuming I got a real good offer from someone) and then went and hopefully found a real good deal on a sale for a PJ 10k buggy hauler or something like that, and possibly spent in the end roughly the same amount (I'm a bit more realistic and realize it probably wouldn't have happened that way, and would have been more like $1500 or more out of my pocket in all reality, to go that route). But doing it this way means the trailer was modified to my needs by me (which brings me satisfaction), and I know it's a fresh trailer up to the task now, plus saved some cash.
Just thought I would share some info for anyone else that may stumble across this thread. My rims have already showed up, and my axles are being dropped at my house today. So hopefully this weekend will get the swap done.
make sure you keep all paper work with you on new axles and springs . also check local and state laws as to legal weight you can haul and how its measured .
in my state the trailer gvw is based off the axles and springs . so even if i swap axles and springs i would need to file paper work and go get it inspected and a new weight tag for it . otherwise if the d.o.t man pulled me he would write me a bunch of tickets for over weight / out of class and such .
Something to keep in mind for sure....but I will say, at least here in Idaho, I guarantee you I won't have a problem at all. In fact, small utility trailers here you don't even need to have a plate on them. Essentially around here, as long as you indicate it's for personal use and not commercial use, they really don't care as much. Shoot, I know a guy who has a flatbed that has a plate with tags on it from a different state that expired back in 2013...and he's never had a single cop pull him over and hassle him about it (I'm not recommending people do that, just trying to paint a picture as to how things are around my neck of the woods for this stuff). Have I said before how much I love living in Idaho? :D
