Best Synthetic Oil (and why)
Which synthetic motor oil is best?
  • Total voters
    257
I didn't read this entire thing, but...
I've run Castrol GTX non-Syn, Mobil 1 Syn (real M1 syn, not blend shiat), and Amsoil in everything I've owned. Synthetic definately has advantages, but not for everybody. The biggest mistake people make is changing Synthetic at Dyno-juice intervals. Amsoil recommends 15K between oil changes and filter changes/ top-offs at 7500. Most true synthetic oil can go 10-15K between changes, easy. If you change oil every 3-5K, there is no reason to run Synthetic, unless it's a really high temp/ high stress situation.
In a 97 Accord EX coupe I owned, I switched to Amsoil at 75K. For the first change, I dropped the oil about 12K later after no filter change. It came out looking like it did when I put it in. This was in FL, during the summer.
On my 96 HD Superglide, I changed to synthetic, and saw a drastic difference in oil pressure, especially when hot. It's not uncommon for the pre twin-cam HD's to run low single digit oil pressure when they're real hot (sitting in traffic, etc.) I've had conventional 20W50 oil give me 1-2 PSI on really hot days. After switching to Amsoil, I saw at least 5 PSI always. I would always run Synthetic on an air cooled engine.
On the same bike, I went from standard Primary case lubricant to HD synthetic lubricant. This caused my clutch to begin slipping under abusive conditions. I immediately drained the Syn and put Dyno juice back in, problem solved. For this reason, I'm hesitant to run Syn in areas that have clutch packs. I do see Syn spec'd for some aftermarket transmissions though, so apparently in some cases their is some benefit. I know the temp protection would be nice to have in an auto.
I just swapped to Mobil 1 in the 5.3 in my 07. I've picked up at least 1 MPG after doing so, but I need to run a few more tanks through it to double check. It only has 5000 miles on it, but I broke it in pretty well so I'm not worried. A lot of people are big on not using Syn early in an engines life. I agree with this during initial break-in, but if this is true then why do so many cars come with M-1 as factory fill? I'm going to change it every 10K and see how it looks. Probably send a sample into a lab, too, on occasion. The 07 came with Syn in the rear differential from the factory.
I think a lot of the myths associated with synthetic are from the old days, when cars were a lot more suscepable to leaks, etc.
Basically, with Synthetic, you're paying for an oil that takes longer amounts of time and higher temps to break down. The frictional losses are also a benefit, but to a lesser extent. If you're not going to take advantage of that, or are from the old school that says oil MUST be changed every couple of thousand miles, it probably won't do any good.
Amsoil is probably the best oil on the planet, IMO, with M1 and some of the others being a close second. Good true synthetic oil is much better than dyno juice, regardless of brand.
What does it matter conventional vs. syn. during a break in period? I know things like the distributor gear and such must be broken in with a mineral based oil in some cases. All in all though, what would syn. hurt if it's extra protection characterists are protecting the engine during the most crucial time in an engines life?
A lot of people claim that Syn is too slippery for components to wear properly early in their life, particularly rings. I've heard a lot of people say to wait 15-20K before you put Syn in an engine. IDK, I've never seen a head to head comparo done. IMO, how you break in an engine is more important than what kind of oil you run during break in.
Here's my .02. I get 2 observations...
I tried Gen-u-ine Harley Syn in my 00 TC Farboy @12k, and all of a sudden, had trouble finding neutral. I'm aware of the prob on the older Evo's with seperate trans, but my TC NEVER had that prob.
II) Blackstone Labs in Indiana(?) told me of all the Syns, Mobil 1 wa the least good, aka worst. But that's relative, I suppose. Kinda' like FRAM oil filter. Look good, but junk. M 1's not that extreme...
OK III) Best oil? What 'bout Royal Purple? Sure have a convincing ad...
Kp said:
Ok,
I am in the break-in period on my new(rebuilt) 454, and I am seriously debating going full-synth once the break-in is over.
I have heard ALOT about Amsoil on this, and other boards, as well as from "heard it from a friend" type sources. I have to say, I have never heard anything bad about it, which may be even more important than all the good stuff when you really think about it.
BUT, what kind of a cost difference are we talking about?
What does 8 qts of Amsoil 10-30, and a filter cost anyway?
Also, is it sold only thru dealers? What if I decide I need to change my oil on a Sat. afternoon? Do I have to wait until my "dealer" can ship it to me and pay shipping on top of that? Or is there a retailer that sells it?
whats the scoop?
Probably about $80 for the full on top of the line Amsoil 10-30, and about $70 for the Economy version....thats shipped to your door, filter, and tax.
That is regular price though, any dealer can set you up as a prefered customer. You then get about %15 off all orders all the time and can order it yourself online or over the phone without having to use a dealer.
You are basically correct, if you all of a sudden have the urdge to run out and change your oil...then no Amsoil isn't too good for you. It takes about 2-3 days for UPS to deliver it. SOME, dealers keep a fair amount of oil in stock, and if you get hooked up with a local guy then you could essentially get it delivered or picked up the same day, but most of us dealers do this for fun in the evenings or something, and we have a life on weekends.:wink1: It just depends on your local dealer's way of operating. For me, I don't leave home from the Ranch very often for more than a few hours, if a guy wanted to swing in and grab a few quarts on a Saturday, I'll likely be around.
I used the qauker state 4x4 syn 3 times can I switch to mobile 1 our would it hurt my motor it has 134k on it
The most important thing to remember when thinking 'bout oil issues, is to CHANGE it. Don't worry about the brand. The sh*tiest glurp from Wally World is better than Royal Purple not changed often enuff.
Detergent oil has no scrubbing bubbles!
Never, NEVER use a FRAM oil filter. They're good for a paperweight, maybe...
Oh yeah, and fill the filter befor installing it.
I had a spec sheet on all the oils a year ago and amzoil was really good but overall Mobil 1 is the best. It has the least solid material in it and the least ash content. Mobil 1 is the ruler of the block when it comes to synthetics. BTW they are all really good(way better than what our engines are designed for so you really cant go wrong)
I wrote this fact(?) a while ago... Blackstone Labs told me that Mobil 1 was "the worst", and their filters the best. I'd find it hard ta believe that mass produced, especially for WallyWorld, can be "the best"!
I enjoy these oil debates.
All oils today are leaps and bounds better than they were just a few years ago and changed regularly most people wont see much benefit to synthetics in water cooled modern engines. (I'm anal and use synthetics).
A benefit of using a full synthetic is not using/buying foreign petroleum oil. (longer drain intervals equals less waste also).
I have used mobil 1 (when you could get it cheap at wally world in the jugs until they changed it and upped the price). I have used amsoil for many years (I have a fleet account (too many vehicle) and got a discount). I would buy a couple cases at a time and wouldn't have to look for it when I needed a change. My 2000 Harley Screaming eagle road glide a little hotter than stock just doesn't like the stuff? Noisier and consumes it? Lately I have been using Red Line in the bike and am very happy. I can't get a discount on the red line and have to order it a head of time. I use 20/50 in the engine and heavy shockproof in the transmission, that stuff is incredible. A little stiff until it warms up when I ride in the winter though, stuff looks like pepto bismol. I use cheap conventional oil in the primary. It is a roller chain and clutch. I just don't see a need for the expensive stuff in there. I am a nutjob and do holeshots, hard downshifts, drive 90-100 for an hour at a time and get 80,000 miles out of my clutch.
I see two real advantages to synthetic oils especially in air cooled engines like HD. First is cold weather pour/flow characteristics. leave a quart of conventional oil and a quart of your favorite synthetic of the same viscosity outside in the cold weather. On a 20-30 degree day pour them both into another container. The synthetic will pour and you may have to squeeze the petroleum oil out. On a cold day which oil will get to your oil passages quicker? Second is high heat. On a Twin Cam HD, oil is squirted onto the bottom of the pistons. How hot do you think the bottom of a piston is? I think this benefits air cooled engines more than liquid cooled unless of course you overheat.
If you are looking for redline or amsoil you can try some of your local HD shops, some of them are carrying it now but you will pay top dollar.
Huh, I used HD's own Syn (Sunoco) in my trans, and wasn't able ta find neutral. I NEVER had that prob 'till I changed the oil. It's a 2000 Fat Boy with 16k.
I like riding at 100+ for 20-30 mins. Gets all the frustrations out!
Wanna' ride/race sometime? My HD riding partner found other friends. Miss the company... and the racing... Ug
Where are you located? I am a Masshole. Always willing to share the road. IMHO get rid of the syn3 crap. HD makes motorcycles and I like the motorcycles they make. They don't make clothes, oil, etc and if I am in the market for any of those things I will try to find a good product for the best price. I would rather not pay a premium price for an inferior product just because they were low bidder with an HD label.
the one problem with having reduced ash content is this - "ash" is another way of saying " anti wear additive"..also known as ZDDP,( zinc ) sulfur, or sodium. These metals have been phased out of every oil ( diesel included), due to emissions regulations. you might find some racing oils out there with these ingredients though..
to make a straight up comparison between mobil one and amsoil, you have to be sure of which products you are looking at - they both make a PAO /ester blend, they both make a group II mineral that's been " processed", and they can call everything they make synthetic, thanks to the castrol court case..synthetic is a marketing term, not an indicator of performance.
the only real difference between commercial oils is the amount of solvents contained versus the amount of lubricant in the bottle.. cheap oil is cheap for a reason.. you may as well just pick which one has the prettiest colored bottle, or least annoying sales presentation, they're all pretty much the same these days..
I've worked construction for over 20 years. I can't sleep past 6:00 even if I go to sleep real late? Usually up at sunrise.
Do you know about Jenni and the 20% off Harley, custom chrome and drag specialties parts? No sales tax and actual shipping charges. Not worth it for an oil filter but I've saved thousands over the years.
Nope. Actually, I rode my FB once this summer to Lake George. 100 miles, then got into my two Corvair Verts. They're Slow, but lotsa room for junk, and my riding buddy disappeared. so it sat. Insurance is a killer, cheaper to sell it and rent one for the little use...
I just sent my nice '62 Spyder for a rebuilt Turbo engine and supension upgrade to Indiana, and one that I bought last month in San Fran, ('64 'vert) will be here at the end of the week.
My Banks Sub 4x4 is here, just forgot my cell phone, so the driver waited for nothing, shame...
Royal Purple-I don't know if it is the best, but I get it pretty cheap and when we pull the motor out of my old Jimmy 2yr old goodwrench350 crate it look brand new inside and I wasn't easy on it I was changing oil about every 3500-4000
