Thunder
3/4 ton status
Umm.. One question. Is the shop that changed the oil the same ones telling you that you need all that work?
Seems kinda strange to me that they had to pull a head to diagnose your engine problems. Disableing your truck is one of the first things a disreputable shop will do to garentee you will use them to do all the work.
A compression test, leak down test and maybe pulling off a valve cover is all that is needed. Or at least thats all i need to diagnose a engine rebuild vs valve job. None of those involves any dissasembly of the engine other than a few bolts and pulling out the spark plugs.
Pretty odd that you have a good running truck. Take it in for an oil change. A few miles after the change everything is knocking and rattling? Hmmm Maybe the monkey in the oil change rack frogot to put in any oil? tighten the drain plug??/ Nahhh That just doesn't happen
