bigbadchev84
I just swapped the hydraulic setup out of my 84' and into my 72' What is the best way to bleed the clutch? I got pedal, But not enough until I pump it a few times
bigblock72 said:I usually remove the slave cylinder and with the line still hooked up push the rod all the way in then let it come back out on its own, repeat a few times until all the air is pushed back up through the master cylinder.
bigblock72 said:No need to open the bleeder, all you need to do is hold the slave so the hose is the high point and stroke the shaft to push the air back up to the master cylinder. The master may have some air trapped and it should come up through the top as well.
