I've got my 10-bolt rear completely disassembled on jack stands. When I pulled the axle seals and bearings, I found a bunch of metal shavings, and large chunks of what appeared to be oily, rusty metal.
I plan on lifting one jack stand so it's on an angle, then spraying a bunch of carb cleaner in one axle tube so that everything runs down into the center section for easy removal. I've heard of folks using some sort of honing on the inside of the tube. Is that necessary or just a nice finishing touch?
After I use the carb cleaner, I know it's going to want to rust up. Should I spray some WD40 in there to keep it from rusting up during the rebuild?
Now I just need the grand for the rebuild parts...
That's one nice purpose-built parts washer
