Hooking straps together with a clevis can be perfectly safe if done correctly. You want the clevis to be on the ground with no slack in the first strap. As long as you are using straps and a clevis that is rated properly there should be no chance of anything going wrong.
Sorry, but this is REALLY BAD advice. /forums/images/graemlins/yikes.gif Have you ever seen what a strap-propelled clevis can do? It can go right through a hood, windshield, head, seatback, etc. /forums/images/graemlins/eek.gif If either strap fails under tension (and just think how many times you have seen people yanking the living snot out of a strap while attempting an extraction) then the clevis is headed the other way at absolutely frightening speeds!
Wheelin' is fun, but not when you or one of your buddies goes home in a body bag. /forums/images/graemlins/doah.gif /forums/images/graemlins/blush.gif Be safe out there! /forums/images/graemlins/thumb.gif
