Grind them down from inside the cab until the metal surrounding the weld is paper thin. Then you can pop the floor panel off the floor brace with a pry bar.
You can pick up a spot weld drill bit designed specifically for drilling out a spot weld at NAPA and most other good parts stores. These bits drill through the top layer of sheet metal only leaving metal underneath undamaged.
