big block intake swap-
drivelineman
Just swapped my offy 360 dual plain- To a 454-0 -and nos plate and quad carb . Now its time to test her out- Jess
What are you using that truck for? I have that intake in a 4500 flange on my cars 427 but I wouldn't use it on a truck that was used for anything but all out competition. Quad Carb?
its For my 64 truck-I usually in 2.4-1 low range under hard pulls in the snow - 2500 stall converter also-Jess
No one else has any comments ? I am unusual in my build I know that -They call me the old iron- I'm sure someone has another name ? Jess
I am interested. Maybe I should put my camaro motor in my k30. Its pissed off till about 3500+ or so, but is does run 10.90s.
Ok, martin it runs 7.00s in the 1/8th which is close enough.
I also have the rpm aluminum heads and roller cam
I soooo wanted to spring for a set of those when I built the 454 for my Camaro. Ended up using a set of iron rectangluar ports.
I'm currious as to how the power will move around with the switch from duel to single.
I am very interested in the curve I get -the carb on top just looks wrong with the spacers and such-I Tried turning it over I think I missed the distributer 1 tooth- it turned over with nothing not even a caugh -I will get it -:) - Jess
