So I got my big block in last night, here are two problems I am noticing right away. The bracket on the power steering pump is slightly too small to bolt up to the water pump on the engine. Also, on my 350 that was in there, there were two lines that ran above the oil filter to the cooler, on this big block it looks like only one, and its not the same as the one i had in there before. Do you guys know where I can get these parts? Or what I should do? I tried autozone, and they were clueless, as well as shcucks.... big supprise there:-) Thanks in advance.
