big block torque converter PAN
73redblaze
Aptos ca
just need that black metal half circle pan that protects a torque converter. if you got one i need it. thanks
what transmission , or are they all the same? i have 2.
edit- automatics have the aluminum cover and manual's have the flat steel plate.
what do you need?
the flex plate? the part the torque convertor bolts too? i should have one of those if your sure that's what you need. i'll look.:rolleyes:
edit - if you truly need a flex plate for a big block, i do not have one.
sorry not the flex plate. the part that covers the torque converter. the pan like thing
This is called a convertor cover and if you have a 2wd trans it will be sheet metal and held on with 4 sheet metal screws, if you have a 4wd trans it will be aluminum and held on with 6 3/8" or 10mm bolts depending on which trans you have.
AFAIK all autos use the same cover.
