Big block tranny/ small block tranny?
Thumper
Alberta Canada
Im pretty sure I know the answer, but want to be sure.
I have a smallblock in front of my 465... I may have a line on a 454... it will bolt in right? Do I need motor mounts? Any differences in clutch flywheel etc?
Thanks.
Mike
tranny will work fine. Pretty sure you can use the same motor mounts too but they do make some just for a BB. I believe the difference in in the height the motor sits..not sure. I have small black mounts on my 454 and it sits a little high. I need a little body lift for my valve cover to clear the brake booster
The only difference might be in the diameter of the clutch that was used from the factory. Some were smaller than others. With a big block twisting on it, I would swap the clutch and pressure plate to the largest size that will fit in the bell housing. /forums/images/graemlins/eek.gif Unless you find that you already have the big 'un. /forums/images/graemlins/cool.gif Either one will fit, but the larger diameter clutch has more holding power...
