so its not a gm but a ford i am helping with .
331 stroker at 425hp/400ft lb at 9.75:1 static comp ratio . 58cc dart pro 1 heads . full roller engine . scat cast crank . other goody parts . here is the engine page . https://www.tristarengines.com/perf...s-retro-fit-hydraulic-roller-camshaft-lifters
he has this to drop on it . http://www.tpsmotorsports.com/kenne...-1986-1993-5-0l-mustang-supercharger-kit.html
using this program calculator https://www.rbracing-rsr.com/compression.htm and knowing he got a 6 / 9 / 12 psi pulley combo for it i played with the #'s and fond a BIG problem .
static comp ratio on new engine is 9.75:1 with the pistons and 58cc heads .
all info specs are at 1k feet above sea level in the calculator.
6...psi = 13.53:1
9...psi = 15.52:1
12 psi = 17.51:1
if we drop to a more normal static for a blower engine that i could see surviving i picked 8.50:1 just to play with the #'s and here is what i got .
6...psi = 11.77:1
9...psi = 13.50:1
12 psi = 15.24:1
also keep in mind this engine was sold as a N/A engine so ring gaps and suck parts are NOT set up for the big boost #'s i see if its going to run and live .
he was talking with tri star engines and told them he was going to put this blower on it and run 6 or 9psi a lot of the time and maybe toss on the 12 psi for fun ( but looks like now at this time ) . they didnt even install a blower cam that is offered for the maker they used and super close to the specs of the one in it now . also the one in it now is 110* LSA and the car is a 87 mustang with stock efi and crane cams fireball box and coil unit .
i just dont see the engine holding up at all to this combo of parts as it sits . i told him i dont play with motors but my own so i am NOT tearing in to this engine to swap stuff / fix stuff / bla bla bla . . . .and this would also void his warranty .
i told him also stock 5.0 blocks are limited to around 550 hp N/A or less on blower setups and strokers . he was thinking stud / main girdle but the builder talked him out of it . . ..
next was the parts LMR sold him for the clutch kit . the 28oz ALUMINUM flywheel is sfi spec and has grd 8 bolts and lockwashers in a ZIP LOCK BAG . .
https://lmr.com/item/SPC-SF82A/Spec-Mustang-Aluminum-Flywheel-28oz-86-95-SF82A
the clutch kit was sold to him as holding up to the power of the new engine and blower . . . i call bull crap this motor if running now would make more than the 567 ft lb torque spec max it shows . https://lmr.com/item/SPC-SF482/Spec-Stage-2-Clutch-Mustang-86-01 its also NOT sfi rated and the pressure plate hardware has socket head allen 12.9 bolts and the thinnest crappy looking lockwashers .
he has a tremec t-56 6 speed in it already when i purchased the car . so we dont know if its built or just a std kit trans . it has some tags / stickers on it i will read up and find info on them . otherwise who knows if the t-56 will hold this much power and survive .
he is doing the car for street and 1/4 mile fun . tubular K-member conversion front end and coil overs . man rack conversion . has bigger brakes and 5 lug swap kit front and rear on the ford 8.8" rear .
most all the stuff he has got is from LMR and i am NOT impressed . there has been ZERO directions given and it all looks like cheeper china grade import junk to me . but i am not sure since its all ford .
i know this is a lot to read . but if any real more in depth engine guys can help we would be greatfull . . . . i am just the install guy and he picked all this stuff and it just showed up or i would have directed him to a better engine before he got this far down the rabbit hole.
tagged in already @Bent77 @Justin V @Shawn maybe @beags86 and if he is lurking anymore @4X4HIGH
6...psi = 13.53:1
9...psi = 15.52:1
12 psi = 17.51:1
6...psi = 11.77:1
9...psi = 13.50:1
12 psi = 15.24:1
https://lmr.com/item/SPC-SF82A/Spec-Mustang-Aluminum-Flywheel-28oz-86-95-SF82Athe clutch kit was sold to him as holding up to the power of the new engine and blower . . . i call bull crap this motor if running now would make more than the 567 ft lb torque spec max it shows . https://lmr.com/item/SPC-SF482/Spec-Stage-2-Clutch-Mustang-86-01 its also NOT sfi rated and the pressure plate hardware has socket head allen 12.9 bolts and the thinnest crappy looking lockwashers .
