W7NB said:
I'm tring to tell if your description of "Clanking and knocking" is a description of mechanical noise or of an issue with missfire/backfire etc. You could have a bad distributor cap and be getting crossfire/arcing which would cause a clank/miss noise. You could have carb issues, distributor issues etc. Bottom line is this a metal on metal noise like a bad wrist pin or valvetrain issue, or is it a missfire issue? How old is the motor and how many miles? What is the cold/warm idles oil pressure? What is the cold/warm vacume, and is it steady or does it wiggle all over like a burnt valve or timing issue?
And lastly, have you done a compression check?
More info please
i have not done a compression check, i do not have a guage.
the noise is kinka like a hollow sound.
the noise is not steady in any way and is spurratic.
the vehicle runs smooth till seems to get to a certain temperature,
then all of a sudden its starts to sputter the noise doe not get any worse though whether cold or warm , it just picks up as you give it more gas but its still spurratic and intermitten never steady.
the oil pressure is always around 50 psi till warm up then idles at about
21psi.
the engine came from a 1975 chevy truck that someone had stuck in the vette who knows when. i do not have a clue how many miles are on it.
oh, also , while running there is no type of exhaust smoke.
i do not think its a carb issue.
the sound done sound more to the back of the motor than the front.
i have had it running with the valve covers off and all looks good.
hope that helps some.
oh, on your wiggle question once warmed up, it does wiggle.
would it make that noise if it was a burnt valve?
