broncoman6524
it could be that the carb is getting too hot...check for vacuum leaks and such. spray stuff with wd40, carb cleaner, those style things. Check the basics.
EDIT: you said taht this just started? if so the the carb getting too hot wouldnt make sense...it would have been doing this.
Torqed em down and used a dab of locktite and all was good. I know, this still doesn't address your miss fire.
. then i pulled the no6 plug and it just was eaten up around the electrode also. all other plugs look good.
