dave_90_blazer
yeah, thats the type
you really need to learn how to set the flame, you should be able to get a book on how to weld/torch from your local library
get the smallest blue flame you can, hold the flame on the spark plug piece for 10 seconds or so, just get it to start glowing red, then turn off the torch for a little while, let the head cool, then do it again, then quick turn off the torch, and tap in the easy-out, it should screw right out(cross your fingers, but this works 99% of the time)
thanks allot thats what i needed to know, i dont have to worry about gas or anyhting do i? im gunna go to the bank in the morning and ill order the torch while im at work, hopefully ill have it soon.
i got six of them out but the hardest 2 are still stuck. im sure you guys know which ones, on the passenger side the 2 midle ones are stuck i cant see the one in the back and havent really tried too much to get it out but the other one i really fd up. i told you guys i got the wrong thing first well when i got the torch i went and got gas for it the next day and they gave me an empty tank so then i got another tank wich was also empty the tird one was good but the thing still didnt work. the check valves were stuck, i fixed them but now i dont know how to use the torch
. i didnt spend too much time with it though i couldnt get it to stop smokeing so i am giveing up and getting it towed to a mechanic
this will be the most expensive tune up ever. but at least i got cool new tools to play with.
