Big Red - 1990 GMC Suburban Ford Super Duty Dana 60 Swap
Hogback Fab R&D rig
I had 80 or so 2009-2011 F250 SD in our fleet I was responsible for, all of them got a right knuckle at least once some of them 2x. The fact that our Security unit was the primary users might have something to do with it.
Wish I'd known about this earlier.
Super duty 60s around here go for 4 to 8 hundred bucks.
A driver side drop a 241 sre inexpensive also. 89 pass 241s are a mint now.
I believe that is this truck from his days at ORD
Nice !
Little bit of late leaf peeping with my folks
pxl_20241009_180527964-jpg.488412
I’m assuming stock won’t work because of the need for a panhard bracket? Or is that integrated into the coil mounts?
The panhard bar itself is the biggest problem, the stock crossmember doesn't work on this swap.
It all bolts together, the crossmember can be used on it's own with any axle.
Are the uprights that’s it’s tied into on that last picture part of the coil mount?
