Biggest alternator I can fit on 83 454 K30?
If V-belt slippage becomes a problem with higher amp alternators you can always run double belts as is used on medium and heavy duty trucks that also have higher amp alternators(ie:Topkick, Kodiak). You'd just have to locate a double pulley for the alternator and the crank. I believe some of the older GM 6.2 diesel pickups also had double alternator belts, correct me if I'm wrong.
Look for any of my threads on the topic, you'll find everything you need.
-- A
I have been, seen a lot of your info on this swap. Maybe I over read the years with the 140a alternator.
In the original case style, there are 90-95A versions for Cadillacs. Search on my name for the part number. I posted it for Dafey somewhere.
EDIT, aw heck, I went and found it:
http://coloradok5.com/forums/showthread.php?t=230956
In the big case, 140A versions come from Pontiac Transport (V6 with rear AC), plus apparently cop cars. This will require re-wiring (easy, coupla plugs from the parts store), a pulley change, and at least on MY big block, required fabbing a new upper bracket. And the Transport ones, at least, aren't cheap.
You *can* get high-output ones in the smaller case, but they tend to be pricey and are not known for long-term reliability. If you have a local alternator-starter-motor shop, you might have your old one rewound by them.
I have one each of the above solutions on my trucks (big block has the 95A Caddy part, smallblock the 140A). I like it 'cuz they're off-the-shelf replacement units I can get anywhere, as opposed to custom-built parts.
-- A
did you replace your charge wire?
if so where does it go?
from alt into harness.. but where to?
