Biggest Tire to run on 10 Bolts
Nope they are all 1/2 ton. Short wheel base and heavy loads are not a good combination. Now I think the militare calls them a 3/4 ton but the military also calls a K30 a 1.25 ton. Really when you think about it that's not that unreasonable. Four 200lb guys is 800lb and throw your gear in there and your quickly over 1000lb.
If it is just for the street it really doesn't matter one bit. Since you aren't going to be putting stress on the axles then you shouldn't come across any probs.
